Power trim for an older motor {1955}
sanssouci
I seem to remember a power motor lifter {not a trim} that would attach to the side of the engine then to the boat for lifting it up in shallow water. I did a search here at iboats but they are more than what I need. Has anyone seen one of these side mounts ?
Re: Power trim for an older motor {1955}
Evinrude/johnson used to make such a unit (I think power tilt, not power trim) for their late fifties and early sixties motors. You can probably buy an aftermarket PT/T unit that will fit your unit, for enough $.
sanssouci
That's exactly what I;m looking for. I tried a search here on iboats but came up with nothing, maybe Joe Reeves will have one or know where I can get one. Thanks.
Sanssouci, If the motor is not too heavy, you can get one of those handles that attach to the top rear of the motor, and provide leverage for tilting it.
I will bet that (unless you are very lucky) you will not find an old OMC unit in good condition, for a reasonable price.
