Power Trim on Yamaha 40
clubchuck
My Yamaha 40 T&T unit seems to have air in it. When you run the trim motor you can hear the tone change like there is cavitation in the pump, the motor goes up and down (slowly) but will "leak" down over time. I have attempted to purge the air by raising the motor and then rotating the lift screw (not sure of the official name) on the port side of the engine which lets the motor down and is mentioned in the manual as a way to purge air from the system. The only place I can find to add fluid is the screw in the center of the pump assembly. How do you tell when it is full? And, how do you bleed the system to get the air out?
99yam40
Re: Power Trim on Yamaha 40
Do a forum search for adding fluid it is asked a lot.
If it is low it is leaking fluid out and needs repaired.
Also leaking down means that there are some internal problems allowing fluid to leak by or leak out.
If you run the motor lifting it up while low it will foam up and not get a good reading on level. Raise and lower by hand to work air out.
