Pre-Alpha Mercruiser U-Joints
zukimud1
I did a search and couldn't find this answer. Do any of you know if any automotive u-joints are a direct replacement for the mercruiser u-joints? I don't want to spend a ton of money for a "marine" u-joint when it the same as a $15 part on a car. If there is, which year/make/model? My outdrive is a 1974 mercruiser 1.<br /><br />Thanks in advance
MooseHootie
Re: Pre-Alpha Mercruiser U-Joints
They are not a ton of money more. ebasicpower.com has them for 19.95 just a few dollars more.
Walt T
Take the Ujoints to an automotive outlet, they should be able to match them up.
NAPA #18-2104.....<br />$34.33 List...<br />$21.96 Jobber....
