Pre Alpha Shifting Problems
Scott in MN
IGNORE THIS POST, DUPLICATE
However, please respond to the other similarly titled thread to share your insight.
'80 pre alpha lower unit on a Mercruiser 228 on a Searay
Shifting has been vauge. Came into dock the boat and had to put it in reverse and then couldn't get it out of reverse. Looked at the shift plate and the black plastic cable end guide on the lower unit shift cable was bending, preventing the cable to be pushed in. I could reach in and straighten it, upon which it would shift into forward. I figured that the previous owner had been trying to shifting it without the engine running, causing it to bend.
I thought this would be an easy fix, just install a new cable end guide and adjust everything per the manuals. I installed the new guide on the cable and while off the shift plate and had no problem pushing the cable in to engage forward, however when I pull on the cable it will not go into reverse. Yes, I have a helper turning the prop when trying to shift. Feels like it is close. It catches a little but not to the point where it is in gear. Seems like the cable needs to slide a little further.
What's going on? Reverse was working. Maybe just barely? I didn't really mess with anything to change anything. Previous owner had his boat mechanic install a new lower unit shift cable last spring and its operation is smooth. Is there something on the other end of the cable prventing it from sliding a little further or engaging reverse.
Re: Pre Alpha Shifting Problems
Duplicate Thread,..........
See the Other Thread by the same Title,+ Poster............
