Preload pin on pre alpha frozen
trm
What the RX for a frozen preload pin. Liquided wrench and some persuasion?
Thanks
swabbie
Limited-Time
Re: Preload pin on pre alpha frozen
Thanks
swabbie
Depending on what pin exactly??............. some serious heat may be prescribed.
captk
there is only one preload pin on a merc #1, the one on the top of the drive shaft. use some penatrant, blaster, liquid wrench etc. and tap the pin with a soft mallet. they are pretty tight. use heat if you must. good luck, bill
trm
Thanks fellas....allways worry about the sometimes weird marine solutions
swabbie
Fishermark
Are you sure it's stuck? That pin is very hard to press.
jerryjerry05
It is a very hard thing to push down.So it might not need freeing at all. Be VERY carefull with heat!!!! You can damage the spring.Use WD and let it set over night. Then tap it gently. Jerry
trm
OK, the pentrant loosened it. Is it suposed to pop out of the drivedshaft?
JustJason
why are you trying to take it out? leave it in there
trm
Your were right on Gerrygerry
Thanks all for ideas
Swabbie
