primer solenoid
halibutts
will my 2000 70hp Johnson run if I just remove the solenoid? Just wondered as mine finally ran a bit before quiting. Closed off the fuel into but did nothing at the carbs.
????-----Do you understand how this solenoid works ?----They work very well and are very reliable too.
halibutts
It tested as bad. 0 on the ohm meter. I removed it to test and clear lines. when it was off I plugged the intake hose and the engine fired off better than the previous attempts, But it quit after abour 40 seconds. wondering if maybe the intake holes to the carbs were plugged it would run?
look back through my posts an see where i've been
Without the primer the motor will be hard to start and you risk damage to the starter motor !
halibutts
come on dude it doesn't start now, I don't know how it could become harder to start.
