primer valve question
jennyo
i have a 1996 evinrude 150 motor what position should the red handle on the primer be in
when the engine is running.
thank you for any info
The red lever is for manual operation of the valve.----For running it should be inline with the valve body.
interalian
There's usually a label on the silencer showing how the valve is to be oriented. Look for that.
Right next to the red circle on this pic:
But the same primer valve was installed on many motors from 9.9 to 250 hp from about 1980 to the last models in 2007.---The very same valve and a much misunderstood item it is !
