kbait
- Joined
- Nov 13, 2007
- Messages
- 2,484
Re: Problem with 1984 Johnson 25hp: plugs get dirty
Thermostats have a spring setup that expands to allow the valve to open when the water gets warm, and closes the valve when it cools down... keeping the cooling water at a consistent temp. Motor was designed to use this. No electrical connection at all.
In fact, you can test a thermostat by placing it in boiling water. Valve should open almost immediately. Then place in cold water and valve will close almost immediately.
