Problem with a shift cable. Maybe?
Tagerman
So I have a 1990 Carver Montego Mercruiser 5.7 Alpha one. Took it out one day everything working fine. Coming into the dock the boat was sticking in gear a little but I thought maybe I had left the throttle engaged. Next day the boat works fine we stop to swim and when we go to head back in the boat won't engage gear. Just reving. Not slipping it just won't engage. After some fiddling it finally went into gear them when we arrived at the dock I had to coast in and have a dock hand help me because it wouldn't reengage. Any ideas? Is this maybe just an adjustment issue? Or something bigger?
Tagerman
Re: Problem with a shift cable. Maybe?
I'm ashamed to say but I couldn't tell you. Was hoping it would last until winter when I was planning on replacing all the boots.
Tagerman
I am leaving on vacation tomorrow but when I get back I'll be trying to fix this! Even a vague idea could be helpful I don't know where to start!
Ayuh,.... My Guess is, the lower shift cable is worn out, 'n needs replacin' now, rather than later,...
Tagerman
I appreciate the recommendation Bond-I I will be visiting the marina in the morning and will be sure to take pictures!
