projects other than boats
Now toying with using a speeduino ECM and running the coils as wasted spark, or running the MSD 60143.
Both have a map sensor to program vac advance
cyclops222
I always like a magneto on any engine. NO NO parts to adjust or replace. Why they were discontinued.
Magnetos have a fixed spark advance. Systems like the Kettering magneto systems are a bit complicated
She looks great. I had to come back for another.
It has brought back memories of my 65 Rivirea. It was one of my favorite car of all I have had.
I'm enjoying seeing folks projects. . .
Here is my current project: Hardwood flooring.
It has been about 25 years since I installed hardwood flooring. I had forgotten how much work it is. Fortunately this stuff is pre-finished. In total it is about 725 Sq. Ft of flooring.:oops:
These are the family room and living room of the summer house. There used to be carpet in these rooms, and at 33 years old, it was ready for replacement. We figured on going with hardwood, instead of carpet.
.View attachment 412122
.View attachment 412124
prefinished is a god sent for using the house while doing it.
Have you seen the jamb saws and the edge flooring nailers (dont need to top nail the edge rows)?
nola mike
The deeper I dig, the more rot I find. So much fun trying to match actual 1908 lumber dimensions to dimensional lumber. 20250917_161608.jpg
I have been redoing my decks and it’s taking for ever as I only have time in the evenings and the days are getting shorter pretty quick. I’m going with stainless cable railings at some point.
Is that Hickory? I like the grain pattern and it looks like its tough stuff and should hold up well.
Spent a few hours on Friday stripping the LS4 down
On-deck next, add a laser-cut 3-4mm steel spacer to go between the block and bell housing to mount the mini starter.
Power wash the motor
Swap the cam to eliminate DOD
Pull the heads to do a port job and swap springs
C6 vette oil pan is on the maybe list. It allows me to get the motor an inch lower.
southkogs
Might need to do the same to a 289 in the near future: I'll be watching with interest. :cool:
