projects other than boats
matt167
yours is exciting in its own way...... like cruising down the highway and it just quitting.... :D.... just kidding. dont you have an old T-bird as well?
Any old ford I have with EEC IV controls, I keep a spare TFI in the glove box. I sold my last one a couple years ago. Never needed a spare though but always hear the stories
southkogs
LOL ... no, you're not! That's funny.
But I do like the convertible. Never owned one before.
I looked at a Tbird, but opted out. My FIL has a whole stable of stuff that we play with: '49 Dodge Wayfairer, '53 Ford Custom, '60 Edsel Ranger, '63 Comet Convertible, '64 Mustang Convertible ... Miata(s), Fiero ... and more ...
I drive 'em all and help work on them. A little over half of the total barn is drive ready.
southkogs
Scott was referencing my timing belt going on the Mustang. I had driven it over a 1,000 miles that weekend, and pulling into Nashville it just konked. I did all sorts of testing and chasing - even changed the fuel pump because of some of the codes I was getting. I was bouncind some ideas off Scott, and he suggested I re-look at the timing belt. It looked like it was fine, but when we spun the engine a second set of eyes proved that the cam was in fact not turning. The belt had stripped it's teeth down in the bottom.
Got my Meziere water pump model. checking fitment now.
still running into performance damper issues. trying to find a damper for the LS4 is difficult.
next big hurdle is finding a good rack and pinion unit for the car. looking for a front steer, preferably a variable ratio, however need 5.5" of throw with 2.5 turns lock-to-lock.
96 Dodge Intrepid is a front steer, power CTO (center take off) with 6.995" of stroke. Would require a PS pump.
Subaru has a 5.25" stroke with electric rack
Looks like the 2011-2013 Jeep/Durango has a remote electric pump that can be used for driving a hydraulic rack
Looks like Volvo s40-s70 from 2006-2013 also have remote pumps
Measuring the ecotec bell housing and the jeep bell housing, transmission input shaft, etc.
The ecotec bell housing is 8.63", the jeep is 6.81" Need to add a 1.81" spacer .
Could always use the extra room after the spacer to add a stator and add magnets to the flywheel and forego the alternator
Anyone know of a large diameter (about 10") 60 amp stator assembly?
stresspoint
if you were to go 2.7 there are a few more options in front mount racks..
in regards yo the thread , my project car is a 06 HSV WL Holden Caprice
with a 3.6 Alloytec V6.
lots of mods have been done by me and the PO ,
the little LY7 V6 had some timing chain issues when i bought the car so that gave me a reason to mod that motor .
mods included : heads , camshafts ,ECU and much more.WP_20190913_14_44_36_Pro.jpgWP_20190913_14_44_36_Pro.jpg
looked going Alloytec/high-value V6. however the motor is a lot taller than the V8, and almost as long.
the LNF 4-banger I have is even taller than the V8 and just as wide and about 2" longer.
looked at Toyota/Lexus 4.0 V8, the volvo V8, etc. keep coming back to the LS4 with custom accessory drive.
looking at rotor/stator assemblies this AM. motorcycle are too small. outboards are 10X the price of industrial/mobile off-highway and come out of the same plants. the miller welding diesel unit may be OK (only $30)
some of the kohler ones may work.
Some correspondence with Meziere on the remote pump I wanted to use. Would require a 6-1/4" or larger pulley to not over speed
Looked at the crank mounted Johnson pumps (SPX Flow). The max temp is way lower than 200F
May need to go with an electric Meziere pump. Which would not work with a stator charge system
Still looking to see if a stator charge system can be adapted.
Just for comparison
The LY7 /LXF (High Feature / Alloytec 60 degree V6)
Weight- 362#
bottom of oilpan to tallest point on manifold 30"
Width 23" to outside of heads 25" to outside of manifolds (LLT engine)
Length from back of block to front of damper 20.5" add a few inches for the high pressure pump out the backside!
Crank CL to bottom of pan is almost 9"
A VERY quick measurement and probably NOT accurate of the L32 3.4L SFI V6 is
24" tall overall
7 1/2" from crank CL to the bottom of the oil pan.
LS4
Weight 374
26.5" width over exhaust manifolds
23.5" from back of block to front of damper
~26" from oil pan to top of carburetor
~ 7" from crank CL to bottom of oil pan
There is the short lived VW W8.
dimensions
mass: 190 kg (419 lb), length: 420 mm (16.5 in) length, width: 710 mm (28.0 in), height: 683 mm (26.9 in)
Power density isn't there. But it is short as can be
Expensive to run, and would require a turbo
Not as cool as the W12 or W16.
car project is put on hold a bit. building the wife a new closet, then building the shed later this spring.
getting 200 board feet of hickory amd 6 panels of 1/4" hickory plywood to make a custom closet for the wife.
regarding the fiat, the stator idea is all but dead as there is no response from any of the custom winders.
the other idea I have. there is a pic of an LS7 conversion. the accessories run off an idler that acts like a jack shaft. eyeballing the diameters, it appears to be a 40% reduction in speed. this appears to be what I need to slow the water pump and AC compressor down.
flashback
Wow you sure make a shift in another direction. Understand the plywood but 200 board of plank is a question.
Quick view. do not have the adjustable shelves in it yet.
Have a new planer coming this week.
Inspiration comes from this. Wife saw it and said, that is how she wants the whole closet.
southkogs
That's cool.
I was playing with some stuff like that a couple years ago: started monkeying around with making furniture DIY with plywood and then played with some shelf ideas.
flashback
Very nice, ! Almost a shame that it's in the closet, your wife will see it every day and that's special.!
Design is almost finished. Looking at 310 board feet of hickory at $5/bdft
