Prop & Anode
marksa1458
Is this how this is supposed to be set up? I have never seen a prop so close to the anode, nor an anode with a notch cut out for the prop????
Doesn't seem right to me - Thanks for your input
Re: Prop & Anode
Merc has 3 anodes. one with a fin, one with an extended fin (that sits farther back) and one that is flat.
it looks like someone put a larger prop and simply trimmed the anode. that is also very common practice.
Re: Prop & Anode
Props with significant 'rake' will hit the standard fin anode. That seems to be the case here. You could use as is or switch to one of the alternate anodes as Scott suggested.
Re: Prop & Anode
Yep, grinding a bit away from the tab is common practice when a huge rake is found on a prop. There are even special tabs made and sold to accommodate props like that but that looks fine.
Philster
Re: Prop & Anode
Note the setback. If you shop for anodes on-line, you'll see numerous options.
marksa1458
Re: Prop & Anode
Many thanks to each of you. Feel much better about things!!!
Texasmark
Re: Prop & Anode
I have one of these and still had to notch it to get my 24P Ballistic XL to clear it on my little 90 Merc. Didn't notice any change in the performance of it.
Mark
