Prop for 1989 Alumacraft with 80 Merc
axlr8
Looking for opinions where I should start at with a 1989 Alumacraft Trophy 170 and a 1983 Mercury 80 Blue Stripe. Never done this before so if I am missing vital information, just ask and I will get back to you.
Looking to get a ballpark area on what prop to use, boat is going to be used for Walleye fishing in northern MN. I dont neccessarily want top speed, I'd rather have good lower end to get up on plane and any top end is just a bonus.
Thanks for any advice that can be offered.
axlr8
Off of what the Mercury Prop selector, they are saying that I should be around the 12.75" Diameter, 21 P 3 blade prop. Mercury part number 77348A45.
I had to use a 2000 75 classic as my motor due to site limitations.
anzomcik
I do not know gear ratio but shooting from hip with not looking at anything for reference i say 21 pitch is high, my guess is 15-17 pitch
axlr8
Is there a way to figure out gear ratio? From looking at the motor? Serial number: 623534
There is a sticky with the info required for prop questions
axlr8
Here is what I have from that:
1: not applicable
2: did not come on the boat, or with prop
3: see above
4: not applicable
5: 1983 Mercury 80 4 cylinder 2 stroke.
6: 1989 Alumacraft Trophy 170 (weight unknown due to current rebuild.)
1 and 4 are vary applicable and what is required to pick a prop. 5 and 6 are optional
So once you post your WOT rpm, we can pick a prop
axlr8
How do I do this? I have never ran the motor/boat together. Should I pick an ideal RPM that other people have run them at? Or am I stuck with having to buy a prop that is "close" and give my results then?
"1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight"
I guess what I am looking for is an 'ideal prop' to start with. And then I am going to be able to get back with more detail of what I am looking to change/fix.
As far as now, its been reccommended that I try a 15-17 pitch prop. I just need something somewhat close to start with and go from there. Im looking at some Michigan Wheel props at the moment.
Sea Rider
See if you can borrow props at a prop shop to try them out, that would be a low investment deal. If boating heavy loaded start with a 15 pitch of your brand preference and report achieved wot rpm on a test run on flat calm no wind water cond.
Happy Boating
axlr8
I called a few local prop shops and they do not offer the prop borrowing like you suggested Sea Rider, but they were able to suggest that for the boat that I am putting the motor on, I should be in the 15-17 range depending on the weight of the load. I do have both a 15 and 17 prop that I picked up used and damaged, and I will be getting those repaired and using them to test on the boat. Thanks for all of the help, I will be back in a while to update my status and what I found worked best for the boat.
