Prop help
gmctodd
Hi Guys,
I have a 2007 Crownline 200LS 5.0L MPI Alpha-1 Gen 2 1.62 ratio w/ 21P SS MM Vengance Prop. There was no sea trial, so I was advised to verify WOT RPM's. I got 54 mph @ 4800rpms with drive trimmed completely out/up. The boat was full of fuel w/ what I would call its normal/light load. The water temp was 48 F and the air temp was around 60 F. The motor has less than 5 hours. Any suggestions?
Thanks,
Todd
05 GMC 2500HD
06 GMC Envoy
07 Crownline 200LS - 5.0 MPI
02 Keystone Sprinter 299RLS
Re: Prop help
Ayuh,.........
Leave it Alone,......... That's Perfect...........
