prop hub going? or cavitation?
jake069
Hi, I've got a 23' avalon pontoon w a merc 115 4 stroke. both 2014. with a few people on the boat, all is fine. When the boat is near max capacity, anything over 1/2 thottle acts like the prop is coming out of the water. Could this be a spun hub? Doesnt matter if we put the heavy guys in the back.
Thanks,
Jake
Have you tried another prop? What is your current prop, brand and model?
Condition of current prop, bent or broken blades?
I believe Mercury makes props specifically for Pontoon Boats.
GA_Boater
When it's loaded with peeps, where are they sitting - In front, lifting the rear?
What happens when the trim is adjusted - Any change?
oldman570
Marking the prop nut and prop will tell what is happening. Place a paint mark on the nut and prop inline, and the next time it happens you will be able to tell if the prop has spun or it is cavitation.
jake069
Prop is in good shape, No change when adjusting trim. People are evenly distributed. we'll move more weight to front or back, with no change
oldman570
With the added weight of the more people, it is more the likely that the prop is to high a pitch for added load. You could go to the dealer where you bought the toon and see if they would let you try a lower pitched prop to see if that is the trouble. The IBoats or Solas prop web site has a prop calculator, and other info, about what makes a good prop for certain
