prop question
gostephen
does any one know what this prop is off when i bought it i was told it would work on my alpha1 the splines are right but the hub is too small and will ventilate, i haven't been able to find any information on it
it is a mach on the side it has 13.5-18 on the hub the numbers are 2353 N 1 G 13.5 18
i know it is a 13.5 diameter 18 pitch
thanks stephen
Re: prop question
Ayuh,... It's for a Mercruy Outboard with the Mid-sized gear case...
