prop question?
jsimms724
Gentlemen : today I removed my prop to be sent out for reconditioning. I noticed that the prop nut was discolored almost has a burnt look to it. I cleaned it up with some carb cleaner and a brush with no changeI am assuming that it gets hot down there where the exaust exits but can a prop nut loose temper and fail,I am new to working an a boat thanks in advance
jestor68
Re: prop question?
No, it won't hurt anything. They all change color over time. :)
Re: prop question?
Ayuh,.... It's Bronze I believe, 'n discolors with age...
There shouldn't be awhole lotta Heat there, if the coolin' system is up to snuff either...
