prop questions
today i took my lower unit off due to needing a impeller and decided to do a inspection on the lower unit and during the inspection i took my prop off as well and noticed that two metal pieces in cased in rubber fell out of prop when taking off not sure what they are or could be they are flat and semi circle in shape any ideas?
Is this a Merc, VP, OB, I/O, other?
Can you post a pic?
