Prop rental?
AviatorJim
Does anyone know a shop that will rent, loan, or exchange props so that you can try one out before you buy it?
Thanks.
-Jim
Or maybe that is a business opportunity.
Texasmark
Re: Prop rental?
Local shops will do that. You must return it in exactly the same condition as received which means go out to known clear water, take your data and take the prop back! No spend the day on the water kind of thing. You will pay a premium for this over a mail order unit, but it is well worth the cost to get the right prop and be done with it.
Mark
jestor68
Re: Prop rental?
They will likely require a deposit; to be applied toward the purchase. Or you buy the prop and get credit toward a different one.
I doubt they will let you walk out the door with more than the one prop at a time.
It goes without saying that there can be no damage in order to get full credit toward another one.
This is another reason why it pays to have established a relationship with a dealer. :)
