Prop Seal leaking??
chappy190
How would you know that your prop seal was leaking??? Alpha 1 Gen 2.
Loosing some gear lube and can't find the leak anywhere. Thanks.
Re: Prop Seal leaking??
Look.............
Drain the gear lube, and do a pressure and vacuum check.
