propeller spacer
tmiller4090
how do you remove the propeller spacer from a 1988 85 hp force.I have a clymer manual but it does not tell. Thanks ,Troy
Re: propeller spacer
I believe it just pulls off.<br />It may be stuck pretty tight if it has not been removed and greased on a regular basis.
tmiller4090
thanks roscoe,it took a little working with but it finally came off.Now I am down to the bearing spool,manual calls for a special puller,is there any other way to remove it? thanks ---Troy
Hmmm, I don't know, never done that.<br />You might try posting a new topic, something like, "removing prop shaft bearing". <br /><br />I'd put it in the general outboards forum, as there is more traffic there. They might move it though.
