PRoper carb rebuild kit?
parttimr
Was looking for the kit here on i-boats under the fall sale and not quite sure which is correct. It's on a 1993 4.3l s/n 0f003200 and is a 2bbl mercarb. any help is appreciated.
The number on the side of the carb on the float housing looks to be 9565A-6 which what I have been able to cross reference a rebuild kit was OEM 3302-804845 which crosses to a Sierra part #18-7097 here on iboats. Can someone confirm this is the correct kit. Still need to find the float replacement.
parttimr
Re: PRoper carb rebuild kit?
Thanks AD for the follow-up confirmation. Just need to make sure it has the straight or 90 degree accelerator pump so guess I'll need to take it apart to be sure before ordering. Thanks again.
