Proper prop for mu boat-HELP!!!
ASI Imperial
Hello all,<br /><br />I have a 140 hp merc gear ratio 1:98r 1982 What shouls be the proper prop I should use?<br /><br />Thanks For Your help!<br /><br />Brian ASI
Re: Proper prop for mu boat-HELP!!!
Depends on the boat, use, and most importantly, your wide open throttle rpm with your current prop.<br /><br />The prop must be selected so that the motor rpm remain in the recommended range.
Jack Shellac
Brian: Each boat and motor rig has it's own specific needs as far as the prop goes. It's not something anyone can guess at. You will learn a lot if you go to the FAQ's and read the Prop Selection item. It's very good information.
