Proper use of power trim (New user)
riesesdad
I've just bought my second boat but this is the first time that I've had power trim. The boat is a 91 18' bayliner with a 90 hp outboard. How do you usually start off with the motor trimmed? Do you start with the motor all the way down and trim up, or some other variation?
What about pulling a skier?
Thanks in advance.
tashasdaddy
Re: Proper use of power trim (New user)
get to know your boat, and where it get up on plane the quickest, also work with the trim till you get the best performance. my boat with it all the way in, pushes the bow down and slows planing, even at top speed if i trim all the way in, it will push the bow down and loose about 8 mph.
Texasmark
Like tas said, get to know "your" boat as all are different.
He said that if he trims all the way down (in) he looses speed. This could mean that his transom is near vertical. My transom tilts back about 20 degrees so I run my tilt farther "in" than he does to get the same effect.
One thing I used to do on another boat with a pretty vertical transom, was to trim all the way in, in preparation for the "hole shot" (getting the boat on plane from a standstill). Then I'd firewall the engine and as soon as the boat started responding, I'd trim out as it was picking up speed. This worked slick.
On top end (Wide Open Throttle ...WOT), my son's boat (pretty vertical transom) can be trimmed out to the highest speed and given rpm but if you continue to trim out, the speed falls off and the rpm increase. Obviously this is over trimming.
Other boats could blow out when over trimmed which means that the speed falls off rapidly and the rpm's go out of sight.....very bad.
On my current boat I cannot trim out as far as I'd like....due to the high slant of my transom so I can't do either of the above.
The speedometer and tach tell you what you want to know about boat attitude. When you get the speed at max (for a given throttle setting) and rpm's at min (for a given speed) you are where you want to be.
Trimming out too far can cause a condition called porposing where the boat's bow rises and falls in an up and down motion. Two ways to combat that: either speed up till it quits (if you can) or trim in till it stops. However, usually right at the point where it wants to porpose is usually your most efficient operating point for that setup.
Mark
tashasdaddy
totallly agree with Mark.
riesesdad
Thanks for the tips. I'm going to get the boat in the water next weekend, and I can't wait to try out the advice!
kenmyfam
Mark is bang on in my book, nothing to add. Take his advice and tips, use them and you will not go wrong.
Texasmark
Thanks tas and ken for your support.
Mark
