Pulling motor suggestions
alws
The gunwales are 6' off the ground when on the trailer. Should I put the hoist in a pickup bed?
With a chain fall that'll reach far the ground?
Bifflefan
Re: Pulling motor suggestions
You can build an "A" frame and put the chain hoist on it.
You can use a good tree, but I dont recommed that.
You can take it apart and have some buddys help you lift it out.
I guess it all depends on why your taking it out, and if you want it out of the boat or just out of the way.
Bt Doctur
could lower the boat off the trailer.
jopes
I had a bobcat which had forks attached to it lift mine out. If you know some one with a service truck and a crane on it that will lift it out as well.
Ayuh,... What Motor,..??
A 3.0l can be disassembled, 'n lifted out by a couple of stout fellas...
