Pulling tube with 30hp
DonHof
Will a 30hp on a 14 foot boat pull a single person tube?
oldjeep
Re: Pulling tube with 30hp
You can pull it slowly, but probabally faster than with the 60hp on my parents pontoon ;)
JASinIL2006
We've pulled our kids for years behind a 14' aluminum v-hull with a 9.9 HP outboard. It was fun when they were little (sub-70 lbs.), mostly because they had low expectations. I could get up on plane (eventually) but I could not get enough speed to swing them outside of the wake. I would think a 30hp might do bit better.
We did find that pulling a tube beat on our 14' aluminum pretty bad... Seemed to put a lot of stress on the transom handles, etc., when zigging ang zagging to make the ride interesting. Ours is a fairly light boat - a bare Sea Nymph.
skibrain
Lots of drag to get a tube on plane.
We tried it with a 14' alum. and a 30 hp Johnson last summer. Did not happen.
I don't know what our prop was other than than it looked stock and in good shape. Maybe with a lower pitch.
250Gimp
BOrrow a tube and give it a try!
I have wakeboarded, tubed, and my buddy even slalomed behind a 40hp four stroke a couple years ago! (I couldn't slalom behind it, at 200 + pounds!)
That was an aluminum fishing boat with a console, so not completely stripped out!
Cheers
i have skied behind a 14' with a 25hp tiller, give it a try.
SierraMark
Had my kids out for the first time this weekend with my 16" Starcraft with a 40HP Mercury and they loved it. Was able to swing them outside the wake. Was going about 25MPH.
-Mark
