Q for clams bendix drive
hammyloz
thanks to you guys my 1982 blueband is sweeeeet
went out today and the cog on the starter motor has worn down so much it dont connect to the flywheel(ever tried using a pull cord on a 115hp) been trying to get one from uk stores with no luck usa stores want 30 bucks for delivery i dont suppose i could just turn the drive upside down or can it only go in one way or if you have one lying about would your delivery price be cheaper or should i just stick to swimming
changing the subject i have learnt so much reading all your comments (and others of course) i now know enough about outboards
Re: Q for clams bendix drive
Do you have any motor junkyards over there? You should be able to get a used one.
How about grinding off the top of the gear to get to fresh teeth?
hammyloz
hi chris
we dont have no outboard junkyards and will grainding off the top seriously work as 3 quarters of it is still fresh
ive found a shop that sells them over here but wants about 100 dollars 69 pound but i think thats a rip off
tashasdaddy
when you figure $30 US delivery, the $100 US doesn't look as bad. he paid $30 US to get it there. it is a part you engine is worthless with out. and you could wait 6 weeks for surface delivery.
Scaaty
The grinding/flipping won't work, as there are tooth relief/ramps in the top of the teeth. Without them, you will tear up the flywheel. Your going to have to pay the price for another
