quad seal lube ?
fishinrado
Hi doing the water pump etc on 98 alpha one gen 11 sterndrive
I have the 2-4-c and the perfect seal for the gaskets etc but does anything go on the quad seal for lube/sealant ?
what about on the two spring seals in the drive shaft seal housing and the small one in the upper
shift shaft housing?
the upper shift shaft seal Came out with a heavy green looking p-text and can't find a positive answer.
Thanks
Re: quad seal lube ?
I usually glue it into place with bellows adhesive, just so it doesn't get knocked out of place during assembly.
fishinrado
thanks , available at cabellas or gander mnt. do you know? the local marine shop doesn't carry squat, ( colorado)
any good substitution like the perma aviation is for perfect seal?
Contact cement, rubber adhesive.
Grub54891
You could just put a dab of grease in the quad,it'll stay there.
