question about 2 part foam
Colorado_Boater
Just a simple question,
Can you trim off the excess foam or does that open the cell and expose them to water penetration
Thanks guys.
Re: question about 2 part foam
you can trim it. surface absorption will be minimal.
closed cell foam is like micro ping-pong balls . . . open cell foam is like micro whiffle balls.
jigngrub
You can paint or epoxy over the cuts to make them a little more water repellant if you like, it smoothes the surface back out.
