Question about control buttons
Mroyce411
Bought a 2021 201dc and one of the control buttons is marked trim tabs, the boat does have trim tabs but they are piston type, having had other boats with trim tabs, if controlled at the helm it is a separate control. Any ideas for why a button would be labeled trim tab it is the second control button from the right side of the panel.
trim tabs should be a pair of switches. up/down for port bow and up/down for starboard bow
do not confuse trim tabs with outdrive/outboard trim/tilt
