question about engine alignment...
indy440
How easy should the tool slide in and out? Right now I can push it in pretty easily with one finger and pull it out with two if I tried, but I can certainly feel a small amount of resistance. Is that good enough?
Re: question about engine alignment...
Ayuh,..... Don't sound to bad,....
Did you read the Grease Tracks,...
Did you rotate the motor 90?,+ recheck, several times,..??
