question about slip?
troypolla
I was doing some calculating, and this shows my slip to be 0.008310. This is in percent right? Or should I move the decimel over 2. But even then it would be less than 1% slip.
5800 rpm at wot
38mph
2.15gear
Re: question about slip?
You're probably Off a Couple of decimal points.....
Anything from 10%,+ Under is considered Ideal.............
72SideWinderSS
If your prop is cupped, you need to add one inch to the actual pitch of the prop. i.e. 15p + 1 for cup = 16p
Running the numbers with 16p = 7%
