- Joined
- Mar 5, 2006
- Messages
- 30,797
Also, If you are going to solder, make sure you use the shrink tube that has heat activated adhesive in them.
http://www.genuinedealz.com/heat-shrink-tubing-adhesive-lined-3-8-inch-diameter-1-ft-black
The crimp connectors that I linked above do not have dielectric grease in them. They actually have a heat activated adhesive in them.
