Question re: installing upper motor mounts
CWKboat
Greetings!
I went in recently to replace my powerhead base gasket and exhaust plate gaskets recently on my '87 XR-2 150 HP, and discovered that my upper and lower motor mounts also needed replacing. I am reinstalling factory rubber mounts. The replacement upper mounts seem to fit perfectly in the upper and power exhaust plates, however it seems difficult to get the 2 plates to sandwich back together completely with the mounts installed (even when off the midsection).
I installed the lower mounts first, and then the lower exhaust plate and gaskets on the midsection. When I installed the tightened up the upper mounts, the top plate did not want to completely mate with the lower plate without leaving a slight gap.
Should the plates go back together readily when installing the 5 bolts through the top plate into the lower plate with the mounts installed? Just wondering if there's a "trick" to making this less of a pain to get back together?
Thanks for any suggestions -- just seems like it shouldn't be quite this difficult to get them to mater together snugly with the upper mounts installed.
Dukedog
if tha bottom half is tha least bit worn they will "move" a tad when ya tighten tha bolts thru tha tiller arm.. sometimes they will "seat right" by tapping them with a rubber mallet while tightenin' those two bolts.. sometimes they won't!.. use no sealant of any kind either...
CWKboat
Thanks, will try to get at it again by the weekend and let you know how it turns out! Thanks again for the reply.
