Question regarding surface piercing \ pulse drive
Status
Not open for further replies.
I tried looking around, i cant seem to find any information. But has anyone on here ever installed one of theese drives, i.e http://www.simplicity-marine.com/smd1.htm. Interesting as it is i have a 28 foot center console with outboard. I would like a single diesel inboard, and this way seems pretty feasible with this or the arneson drives. Any input would be appreciated.
Thanks
Jim
Re: Question regarding surface piercing \ pulse drive
What type of hull design is required, this is a deep V, really deep.
Ayuh,.... Like Bubba says,...
I really Doubt your transom looks Anything like This....
With an Outboard, or Sterndrive the boat bottom is Straight to the transom,...
Not pocketed like the picture...
flargin
If I read the simplicity web site correctly, this can be added aftermarket and attached to the transom?
Wow that would be one heck of a modification....
"Because Simplicity Marine Drives are simi-custom it allows us the ability to fit any transom from 0-16 degree and retrofit to existing sterndrives. The SMD drive will cover the old hole left by most brands of sterndrives, eliminating costly modifications. "
thats a WHOLE add on to the back of your transom(notice the dotted lines), The pocket, the rudders shaft and prop is the kit, continue reading their material and you will see.
thats why it peaked my interest, this thing looks real cool(espeacially with a diesel). Just need someone to answer this that has worked on/owned/or piloted theese
Ayuh,... Seeing that You've done some Readin',... What's the bottom line Price tag on it,..??
45Auto
Have you priced a 200 ft-lb torque marine diesel and marine transmission lately??? You do realize that the $5449 is just the adapter unit for the end of your boat, it doesn't include the diesel or transmission?
Twin outboards might start looking like a good deal .....
They have some prices including engine and transmission at the bottom of this page, they start at $19,995 for the little one with a Hurth transmission and the Simplicity drive .....
http://www.simplicity-marine.com/mpower.htm#Mpower
yes i am aware the 5440 is the surface drive only. i can find 6bt for under 5k. the the marine tranny 2-3k. total 15k. New twin 200's more like 30K. I have 1 250 0x66 now, if i got a counter rotating for 6-7k I know have a boat that cruises 30-35knts @ 17gph per side. I'm just kicking around the idea , i'm more curious how these work in the real world. I know some boats come with them. I was hoping someone on here used one or drove one just so i can get first hand experience if it was worth it (handling, fuel economy, etc etc)
Status
