questoion about the cables for batteries??
AngelC
Hey Guys,
How's it going out their?
I have a question about my battery cables. Do I have to buy marine grade cable? or can I get by purchasing 4awg from an Auto parts store? My local Napa Auto Parts sells the cable by the foot and puts the eyelids on for me for about $1.99 a ft. verses West Marine or Boatersworld that is WAY MORE expensive and alomost identical besides the coating on the wire I presume. What do you fellows think I just need two cuts of 4ft of red and one cut of 6ft. black for a ground to hook up my battery selector switch. Can I get by with using this cable?? Any input as always very much appreciated.
Thank you
__________________
Silvertip
Re: questoion about the cables for batteries??
There are no grounds on a battery selector switch! Positive from each of the two batteries to the BAT 1 and BAT 2 terminals. Negatives on both batteries connect together and then to the engine block. COM on the switch to the engine start solenoid. You can use the bulk cable but I would go one step farther and install shrink tubing over the terminal ends. Just a little extra protection.
In freshwater you could probably get away with it. If the boat is kept in saltwater then I?d used the tinned stuff.
The tinned copper might be a good bit more expensive but you?ll get 3 times the service out of it. A cable problem out on the water will cost you a good bit more.
slasmith1
The bulk cable is not designed to hold up in a marine environment. You can save a little now but when it fails prematurely and you need to pay a tow bill on the water you will see why a little more $ now is worth it.
AngelC
Thanks for the input guys:)
JB
Automotive battery cable does not have the flexibility to stand up to the movement of an outboard or the corrosion resistance to stand up to a marine environment.
Using the cheap stuff is a false economy because when it fails it will cost you a lot more than you thought you saved.
dan t.
I made up all my own battery cables out of #1 ga welding cable, ends crimped, soldered,and sealed with HD heat shrink. 6years trouble free.
dan t.
forgot to add,6 months per year moored in salt water:D
tashasdaddy
battery cables, and connections, cause more starting problems than anything else imho.
pvanv
Agreed with TD. Marine wire is best.
