Quick question for bondo......
packerman
I like your "drain'er dry" theory. Makes perfect sense. Better, cheaper and easier by far. That said, what is MerCruiser's theory of adding AF mix in colder climates? Also a quick question as to why the plugs aren't left out for the winter? How about condesate during heating and cooling if left empty/dry. Could this build up if the plugs are not left out. Looking forward to your thoughts......... you seem to believe in your way.
Re: Quick question for bondo......
Oh,........ Btw,.......
When you Don't see your post after using your Back Button,.........
Remember,........ The Refresh Button is Your Friend................d:)
packerman
Appreciate your reply and thoughts about the "my way,dry way" theory. Also the FYI to refresh. Let me tell ya though Bond-o...........you can really sort them out if they actually answer both........ huh.
