quick question's regarding filling outdrive and replacing outdrive.
o'neal
I've been reading everything I can on my starcraft boat I bought awhile back until my head hurts...I know,pretty basic questions but I'm abit unclear,Thanks.
Filling outdrive? call's for 32fl oz(goes in at the vent near the top??)
When replacing outdrive the use of the alignment tool is required...yes???
Re: quick question's regarding filling outdrive and replacing outdrive.
In order
No, you fill from the bottom, and 32oz. is not enough.
Yes, you need to check the alignment.
Also understand that in this forum, we could care less what the boat is, we need to know what engine, drive, year, serial number and information like that to answer your engine and drive questions.
o'neal
1978 starcraft,120,mercruiser OD w/a sticker stamped with 532.631 and a 1.98R...I could have sworn the manual in the adult forum stated fill back to 32oz.Off to reading some more,thanks for the reply don.
Ayuh,...I don't remember the exact number, but it takes Over a quart, but less than 2 to fill it,...
Always from the bottom...
