Kiwi
- Joined
- Jun 7, 2001
- Messages
- 156
When I lower my engine the Trim pump sounds as it should until it gets into the trim range of movement when the pump comes under considerable strain. On the way up in all positions the pump runs freely. Its always been like that since I have owned this boat, but from other OMC systems I have had over the years this isnt the case. I understand that there is a slight change to the sound of the pump under trim rather than tilt but this is excessive. Any ideas ? I still have the original Calco pump.
Thanks
Thanks
