QuickSilver 3000 Advance throttle
Stefano
i cant seem to rev up the motor with out putting the motor in to gear can anyone help
Re: QuickSilver 3000 Advance throttle
At the bottom of the shift arm, in the center where it pivots, is a button, push it in, advance the throttle without putting it in gear.
If it will not work as it should, something is wrong inside.
To disassemble, push in the button, advance the throttle, pry the button out to expose the hardware.
seabob4
Keep in mind all, older Merc sidemounts, push and hold the "throttle only" button and move the lever to full reverse to remove the button. Newer models, do the same except move the lever to full forward...
