Rattling noice in Alpha II
victorc1
Hello, I have a 1995 Mercruiser 3.0 LX with an Alpha II, when I make a turn a rattling noice sounds from the Alpha II. I checked the driveshaft and gimbal bearing and it seems to be fine. Also when I am going forward on the boat it rattles and the boat vibrates I have to adjust the tilt on the Alpha II for it to stop. Can someone tell me what this problem is? Thank You.
achris
More fish than mountain goat
Re: Rattling noice in Alpha II
Sounds like a uni-joint is loose or the clip has come off and it's move out of position..
Chris.......
victorc1
Okay, guess I'll remove the transmission again and check it thoroughly. Thanks
Ayuh,... Hearing the Shutters,+ Feeling the U-joints, or possibly Bad prop/ Bent propshaft...
