Raw water pump - Help
old bird
Water is dripping from my water pump. I guess its a shaft seal.
Is replacing the seals something I can do ?
77 Formula, 454, 330hp.
Trs drives, MercTrans
Pump #46-807151
Thanks
JWebber
Re: Raw water pump - Help
Are you talking about the engine water pump (circulating pump)or the impeller in the outdrive?
Ayuh,... Or an engine mounted raw waterpump,..??
What pump do you have,..??
old bird
Engine mounted Raw Water Pump. Merc #46-807151, or 46-72774A32
Leaking out of that little hole .
Figure it needs new seals. .
Is replacing those seals something I can do?
Or ???, can someome else do it, or ???
Thanks
paultjohnson
Those are repairiable huh ? i was picturing a car like water pump l
Merc has parts listed for the 46-72774A32 pump.
