Raw Water Pump Won't Pump From Stern Drive But Will From Bucket?
sltaylor1024
Not sure how to start new thread so I will type here. We just replaced the impeller in our pump and tested it and it does pump out of a bucket but will not pump from the foot...is the hose from the foot clogged? is there an impeller in the foot? lost!!!
Fun Times
Hi there sltaylor1024, welcome to iboats!:)
To help you out with how to start a new thread of your own, please have a look at this link that explains how to go about starting a new thread. http://forums.iboats.com/forum-rules-guidelines/how-post-new-thread-573291.html
Once you have posted in a thread or created a new thread of your own, you should see a green arrow on the left side of the Icon Legend indicating this thread contains a message written by you or you have posted in this thread. Be sure to find and follow up in your threads so it's more helpful to you. Also if you click on your user name, you will be able to find your past threads/posts much easier.
As for your question above, we will need as much information as you can provide us about what engine and stern drive you have including the year and any serial or model numbers you may have. Also what have you tried to correct the problem thus far.
We went ahead and created a new thread for you here!!!
Thank you and good luck.:)
