Raymarine A50D
portd
Has any one tried a Raymarine L460 Transducer on Raymarine A50D , Raymarine does carry a jumper cable to this , my boat has the L460 on it , or should i install the new one that came with it
Thanks
Re: Raymarine A50D
You could hook up several different transducers to the L460. If the connectors match, the chances are pretty good that it would work. You would need to know which transducer you have one to be sure of the compatibility.
Having said that, transducers don?t live forever. I would change it out just to make sure I had a fresh transducer on the back.
