Reactor Tailgate Light Bar Giveaway
MISSBAJA
This is pretty cool! Hope I win one!:p
Anybody seen them on trailors yet? Waterproof...
truck LIGHT_bar
Gary H NC
Re: Reactor Tailgate Light Bar Giveaway
I have seen them on many pick ups.Not on boat trailers..Pretty nice lights.
Hope you win!;)
tashasdaddy
i would not spend $89.00 for them.
bowman316
those things are broken on every pick up i have seen them on.
because you break them when stuff falls thru the tail gate when you are putting stuff like wood in your bed.
waste of money.
Silvertip
And they may not be legal. Plugging them into a four way trailer connector on your truck, or wiring into the brake/turn light circuit on a trailer means they work ok as a brake light. However, the turn signals also run off the brake/turn circuit so when your turn signals are in operation the light bar flashes. People will be so intent on watching the light bar they don't notice which way you are turning. I've seen these and similar light bars and they are annoying. If you do install one, install it as a true brake light and that means running a wire to the brake light switch or to the separate brake circuit if your vehicle has separate brake and turn circuits.
maxturbo
I have one on my ford pick up now for about a year. The brand is Recon. Never had a problem with it. And it plugs into the 4way trailer connect. When ur blinker is on only that side flashes. When in rev. The bar turns white, also giving u better visability at night. When u brake the hole bar turns red just like ur brake lights. Love it.
kenmyfam
Loads of money for what it is though !!!
Mark42
I've seen a few. They all had "dead" spots in the light bar. Not worth the $89.
