Rebuilding Johnson outboard
PierBridge
ic 3 lock tabs on these 5 bolts plus one open hole...should all 5 have lock tabs
PierBridge
I believe I'm reading the manual and it says all five lower and centers must have locked tabs?
PierBridge
I believe the manual is telling me all 5 of these bolts should have lock tabs only 3 do?
PierBridge
Oh ok misread that ...middle and top bolts do bottom bolts do not.
Still missing the middle bolt there it seems..
PierBridge
I believe some years these were brass/ bronze bolts.----Yes there is one bolt missing.-----They get very hot.----Lots of vibration.-----They come loose.-----A 1973 model 135 HP ??----What rebuilding are you doing ??
I doubt it is a 1992 model 90 HP .-----I doubt that a 1992 has those filler blocks !!!----Post more pictures of cowling / power head and cover that bolts on to cover exhaust ports.
