rebuilt engine question
longisldr
thanks to this forum i was able to identify the problem with my boat engine. i found a hole in a piston and was going to get a new or remanufactured engine. i was told it would be better to have my engine rebuilt and it would save me alot of money. i have no idea what a rebuild of my engine would cost. i have a 1985 mercruiser 4 cyl, 3.0 liter , 140 hp, 181 c.i. engine. any suggestions?????
Re: rebuilt engine question
Depending on the amount of Machine Work nessessary,....And,... How much of the Labor You do,.....<br /><br />You're looking at between $500. and $1500.00...........
whywhyzed
Banned
What caused the hole in the piston? <br />Best to find out before you put a new piston in.
longisldr
bondo, i am bringing it today for an estimate. thanks for the price range. i am betting toward the $1500 area. and hystat, i believe it was timing related since it occurred after a tune up and the timing was never checked. ran rough for a little while and then BOOM.
russman
i had one rebuilt at a local motor rebuilder<br />about 10 years ago. i was told they could order a marine engine, rebuild kit with pistons rings,ect.<br /><br />i pulled the motor and delivered it to them. <br />it was about $800 10 tears ago so 1200 ish maybe close. you will have to let us know what the estimite is <br /><br />as for the hole in the piston i dont think being out of timmming will cause that, enless the timming chain has skipped a few teeth and the piston crashed in to a valve that was down at the wrong time.<br /><br />good luck<br /><br /><br />russman
Well,........<br /><br />As longisldrhas Learned,..........<br /><br />Advanced Igntion Timing,.... Is but Only 1 of the Many causes of Detonation,.......... <br /><br />And,....... That'll Burn a Hole Thru a Piston,.......... In A HURRY.......... ;) :( :rolleyes:
longisldr
the price quote i got was $1350. bringing him just the block and head to be rebuilt. that was the price completely stripped down by me and reinstalled by me. it sounds a little high, any opinions on this?????
If you're getting back a Rebuilt Fully Assembled Long Block Motor,..........<br /><br />That's Not all that Bad,...... At All..........
rob935
sounds pretty reasonable as it should last for years if looked after, you should price a bobtail just for reference?
lilmandavis
i spent 1600 on a long block vortec no core charge from rapido marine in miami 5.7 liter and thats delivered
longisldr
thanks to all for your advice. i think i am going to get a bobtail professionally installed so i dont have to worry about anything i did wrong. my only worry will be paying for the engine!!!
