Register Homemade boat in WI
MotorMan101
Hello all has anyone registered a home made boat in WI and knows what forms I need to get a hull ID? I have a homemade pontoon that I would like to put a motor on...but need to register it for that...
walk into your local DNR office. I found that to be best. The best one I have had luck with is the one Brown County.
Check with the Wisconsin DNR . . . it appears that the state will assign you a HIN . . . the Pre-fix will be "WSZ"
DNR reps at the service center on Rib Mountain Drive have been helpful to me.
Avoid the Milwaukee office.
You will need a list of materials used and receipts for supplies used.
agreed, avoid Milwaukee and Waukesha
Two Rivers is hit-or miss with the staff.
