Remembered the plug forgot the....
swire
So there I was planning all week to take my boat to the lake to catch the bass that I heard were hitting. I picked up the bait and had everything ready the night before. That way in the morning all I had to do was load up the boat and I would be good to go. Morning came so I loaded up the boat and headed out. About 30 minutes into the trip it suddenly hit me I left the bait at home. That was no big deal I could just buy more at the corner bait shop. 30 minutes later I get to the lake and get the bait then head down to the lake. I undo the straps for the boat, get the plug out of the boat and put it in place, then I go to grab the keys. THE KEYS! I left them at home! There was no way I was driving an hour back home and then an hour back to the lake. All hope was not lost as I had worked on the electrical system enough to know how to hot wire the ignition switch.<br /><br />All was working well until the motor started acting up later in the day. It lost 3/4 of it's power and just didn't want to run right. Through a series of trying troubleshoot and test the motor something else happend. While cranking it over I heard a pop like a backfire and then the engine sounded like it wasn't getting any fuel. I turn around to see the smoke coming from the engine hood. Knowing engines don't smoke like that I quickly ran back to it and pulled the small access panel open to get a better view. Can you guess what happend? The sudden rush of oxygen turned the smoke into flames and fire shot out of the access panel. I quickly grabbed my fire extingisher and pushed the button only to be covered in a white cloud of dust as the wind blew a lot of the chemical back on me. The cloud of dust hung in the air, the water was covered in white dust, my boat was covered in dust, and I was covered in dust. All hope was not lost though as I had my trolling motor. I was only about 2 miles away from the dock going into the wind and had a pretty full battery. I spent the next two hours bobbing through the lake at 1 MPH slowly making my way back to the ramp.<br /><br />My fire extingisher was right there when I needed it and as a result the damage was very minimal. It looks like fuel is what caused the fire. I'm not sure where it came from but the starter or generator must have sparked the fire when I turned it over. I used to think fire extingishers weren't that important to have readily available. I was wrong and will definately be mounting the new one in a just as accessible place.<br /><br />Maybe I should have just stayed home in bed that day. But hey at least the weather was nice.
sangerwaker
Re: Remembered the plug forgot the....
Nice to see the positive attitude, swire! I (thankfully) have never had to use my fire extinguisher, but it is always onboard and ready for action. Glad you were prepared and your damage was minimal.
brother chris
Glad to hear everything wasn't wrecked and you never caught on fire. <br />Did you ever figure out why there was smoke? <br />I'm interested to find out why that happened.
swire
Originally posted by brother chris:<br /> Glad to hear everything wasn't wrecked and you never caught on fire. <br />Did you ever figure out why there was smoke? <br />I'm interested to find out why that happened.
From what I can figure out it must have been some sort of fuel fire. I checked all the wiring and didn't notice any that had shorted out. So the smoke wasn't from melting plastic. There was some foam on the inside of the motor cover that was melted that might have been what was smoking. Or it could have just been there wasn't enough oxygen inside the cover for the fire to burn clean so it was just smoke from smoldering fire.<br /><br />The reason for the good attitude is this was just my first boat and sort of a project at that. Other than a huge amount of time invested there isn't much of a loss. The boat has had things breaking on it ever since I got it, so it's not too suprising that something like this happend.
Swire, That dry chemical stuff in the fire extinguisher is very corrosive to aluminum and brass pieces of the motor. Make sure you have cleaned it up well.<br /><br />On a related thought. <br /><br />Question: If you are spraying ether into a cranking motor, what is the most likely next event?<br /><br />a) The motor starts.<br />b) The motor catches fire with a nice "swoosh"<br /><br />Easy answer, They catch fire everytime!
Seamus
Why is you guys always spend so much time on the insignificant details of your fishing trips (engines bursting into flame and such) and never get around to telling us how many fish you caught?
Mr.Ladyfish
:D :D :D :D :D :D :D
lawyertob
Originally posted by Seamus McFadden:<br /> Why is you guys always spend so much time on the insignificant details of your fishing trips (engines bursting into flame and such) and never get around to telling us how many fish you caught?
Besides, no one will ever believe you when you say how many fish you caught...but they will always believe that you managed to set your boat on fire. ;) <br /><br />Just my $0.02 worth,<br />Joe
