removed rust and paint off prop
h.l hunley
i have a 1983 johnson 115hp motor on a ebbtide dyna trak 162 my stainless prop is a 13x19 painted black. it had minor surface rust on the tips of each blade were the paint had wore off over time. I cleaned and stripped all the rust and remaining paint off the prop. my question since it is not the polished stainless finish, can I leave it the way it is now or should I paint it again.also this boat is only in fresh water. THANKS FOR ANY INFO:)
jerryjerry05
Re: removed rust and paint off prop
You can repaint it to make it look pretty.Or don't waste your time.It won't hurt anything the way it is.J
